Problém po provedeném flashování
Ahojte,
ulakomil som sa na novu oficialnu ROM .. ale kedze mam CZ HD a bola urcena pre ENG HD tak som HD unlockol podla navodu na smartwiki ... potom som natlacil novu ENG ROM a nastali velke problemy ..
- PRI NABEHU ZBLBME DISPLAY (farby ako pri mode 4 farby - pomoze vypnut zapnut display)
- NABEH TOUCH FLO JE NESKUTOCNE POMALE - CCA 5 MINUT
- NEDA SA ZAPNUT TELEFONNY MODUL
pls POMOZTE ..
ten telefon je moj pracovny nastroj
uz by som bol aj za spat uzavretie ROM a danie original urcenej pre tento model ale NEVIEM JU NIKDE STIAHNUT ...
Vie mi niekto pomoct co s tym ??? alebo nejaku po vsetkych strankach 100% rom ???
Upraven název vlákna. admin
pls POMOZTE ..
Známá věc, postupuj podle tohoto návodu: http://www.wmmania.cz/content.php?id=1186
Potrebujes nahrat namisto HardSPL,stock SPL1.14 na ktery tam mas odkaz a potom pomoci USPL nahrajes tuto novou oficialni rom.
Je to opravdu jednoduche.
V bootloaderu jsi..? Co jeste pouzivas za operacni system.?? Vim, ze na XDA se resi problem s Vistama...
zkus toto:
davenash - USPL doesn't work with the current activesync drivers that are installed in Windows 7 and Vista.
Vista it is fixable by installing the old drivers, and then rebooting so you allow the unsigned drivers to work.
Windows 7 does not allow unsigned drivers at all so currently it's not usable there.
For Vista i've made a very dirty guide which you can find at
