Specifický TreeView - problém kopie nodů do jiného
Dobrý den,
vyuzivam jednu tridu ke tvorbe specifickych TreeViewu a potrebuji ji naklonovat do
dalsiho "specifickeho" objektu typu TreeView.
Pokud by byla řeč o standardním objektu, pak by kopie byla provedena následně:
NewTreeView.Nodes.Add((TreeNode)OldTreeView.Clone());
A basta fidli....., že jo.
Jenomže já v tom mám trochu komplikaci:
Odvozena trida tedy vypada nasledovne:
[CODE]
namespace MyNode
public class FileTreeNode : TreeNode
private string m_path;
private FileNodeType m_nodeType;
private bool m_directoryFilled;
public FileTreeNode(FileNodeType nodeType, string path)
if (String.IsNullOrEmpty(path))
throw new ArgumentException("path");
m_nodeType = nodeType;
m_path = path;
m_directoryFilled = false;
public enum FileNodeType
File,
Directory
public string Path
get
return m_path;
public FileNodeType NodeType
get
return m_nodeType;
public bool IsDirectoryFilled
get
return m_directoryFilled;
set
m_directoryFilled = value;
class FileTreeviw : TreeView
public delegate void FileTreeviewDirectoryExpandHandler(object sender, FileTreeviewViewDirectoryExpandEventArgs e);
public event FileTreeviewDirectoryExpandHandler DirectoryDataNeeded;
protected override void OnBeforeExpand(TreeViewCancelEventArgs e)
FileTreeNode currNode = e.Node as FileTreeNode;
if (currNode != null)
if ((currNode.NodeType == FileTreeNode.FileNodeType.Directory) &&
(!currNode.IsDirectoryFilled))
OnDirectoryDataNeeded(new FileTreeviewViewDirectoryExpandEventArgs(currNode));
base.OnBeforeExpand(e);
protected void OnDirectoryDataNeeded(FileTreeviewViewDirectoryExpandEventArgs e)
if (DirectoryDataNeeded != null)
DirectoryDataNeeded(this, e);
public class FileTreeviewViewDirectoryExpandEventArgs : EventArgs
private FileTreeNode m_node;
public FileTreeviewViewDirectoryExpandEventArgs(FileTreeNode node)
if (node == null)
throw new ArgumentNullException("node");
m_node = node;
public FileTreeNode CurrentNode
get
return m_node;
[/CODE]
Jak je vidno, tak se jedna o objekt, ktery je urcen pro reprezentaci souboru a adresaru.
No a muj cely problem je jen v tom, jak VLASTNE udelat kopii z toho stareho TreeViewu do noveho a to tím způsobem, že v novem zůstanou pouze adresáře, ale nebudou tam soubory.
Pochopitelne lacine reseni je, nakopirovat tam adresare a soubory "rucne" podobne, jako u puvodniho modifikovaneho objektu.
Ovsem tady je problem casova narocnost (a optimalizace)
Zabere to cca 3s, kdezto kopie je defakto okamzite.
Nemate nejakou jednoduchou radu ci ukazku ?
Uz jsem zkousel vsechno a "jebu" se s tim fakt dlouho a porad mi to nechce docvaknout...
Tohle jsem zkousel a porad nic:
Treeviw2.Nodes.Add((MyNode.FileTreeNode) Treeviw1.Nodes[0].Clone());
S timhle to padne na "System.InvalidCastException"
Čili postup se (nejspíše) bude skládat ze dvou kroků.
1)
Prvním je vytvoření kopie toho specificky upraveného objektu
2)
Je odmazání nodů, které mají atributovou vlastnost rovnu typu
MyNode.FileTreeNode.FileNodeType.File
Prosim pomozte, nebo se z toho pri me inteligenci zcvoknu, totalne !
Dekuji
[CODE]
namespace MyNode
m_path = path;
File,
Directory
public string Path
get
return m_path;
get
return m_nodeType;
get
set
if (node == null)
m_node = node;
get
return m_node;
[/CODE]
1)
2)
Dekuji
Cau, predne se priznam, ze jazyk, kterym pises neznam, ale mam myslenku, ktera ti treba pomuze. Ja bych to (v jinem jazyku) ;) udelal tak, ze bych clone() pretizil a to tak, ze bych zavolal clone predka (tim ziskas tu rychlou kopii) a pak vymazal ty soubory (to bude snad take rychle). Tim tvuj objekt bude umet nove clone, ktere dela to, co chces. :yes:
Jestli je to v tvem jazyku blbost, tak se omlouvam. :disgusted:
No já zkouším toto, ale píše mi to neplatné přetypování:
[CODE]
namespace MyNode
m_path = path;
File,
Directory
public string Path
get
return m_path;
get
return m_nodeType;
get
set
public FileTreeNode CloneIt()
FileTreeNode b = new FileTreeNode(NodeType, m_path);
foreach (FileTreeNode n in Nodes) b.Nodes.Add(n.CloneIt());
return b;
if (node == null)
m_node = node;
get
return m_node;
[/CODE]
METODU VOLAM NASLEDNE:
[CODE]fileTreeviw2.Nodes[0].Nodes.Add(((MyNode.FileTreeNode)fileTreeviw1.Nodes[0]).CloneIt());[/CODE]
Hlasi to vyjimku - neplatne pretipovani, netusi nekdo proc, nebo nejaky navrh ?
[CODE]
namespace MyNode
m_path = path;
File,
Directory
public string Path
get
return m_path;
get
return m_nodeType;
get
set
return b;
if (node == null)
m_node = node;
get
return m_node;
[/CODE]
